After modifying my XLSForm to better capture the questions of my project I can no longer submit the surveys. The error message says "This survey could not be sent due to the following error:" and then lists the instance_name. If I do not define the instance_name the error just lists the default name. I am hoping someone on here has run into this issue before and knows how to fix it? I know when I define the instance name it is correct (e.g., ${site_number} ) so all previous posts dealing with something similar do not apply.
Thanks!
