Hi Team,
I have put together a survey which uses a select multiple question. This survey is for use within the browser, rather than the mobile application. I have a select multiple with an 'other' option, using the manual option to collect other responses.
When I open the survey in a browser on my mobile, it shows the name of the selected choices under the question. This is not optimal because the name does not match the label. When I switch over to desktop view in my browser the question displays as expected without the choice names visible.
Is there anything that I can do to remove the visibility of the choice names?
Thanks, Emily
