Hi, I'm having an issue with an existing form, when I try to share results to a group in the collaborate tab -> share results, it says Failed to save: Cannot read properties of undefined (reading 'replace'). This is the only setting that throws that error, as I can change the share survey, update survey, etc., settings. Specifically, a problem with 'sharing results' to anyone.
I confirmed that all related and linked content (web maps, hosted/view layers, dashboard) is shared with the same group, same sharing settings, and all exist within the same folder. This survey was shared with that same group a week ago and they had access to the data, and now they don't, seemingly overnight.
No issues with the form itself as entries can still be made, I analyzed and republished it to make sure. This seems to be only affecting the survey123 website, or the share results settings. Not a group specific issue as I can't share results with anyone (org or public). Any advice would be appreciated, I can provide more information if need be, just not sure what is pertinent. Thanks!
