I have a workflow which requires the functionality of repeat but what I actually need is the sum of the values contained with in the repeat. i.e. count the number of desks and chairs (and other equipment) within each room (there can be any number of rooms hence the repeat). Outside the repeat I use the sum function to get the total number of desk, chairs, etc. within each building which is what is required. Thus I don’t need the repeat published onto the feature service just the sum of these values.
I know when one doesn’t want a field to be published to an online feature service put “null” value into the “bind::esri:fieldType” field.
I have tried do the same (putting null) against the repeat field itself but the repeat still publishes.
I know I can removed the repeat table using the REST API when the data is published/sent to the online feature service.
Is there a setting/configuration which will stop a repeat from being added to the online feature service when publishing the survey123?
