I have a Survey that I have re-built twice in web design and have generated the same issue. When I put the second note in the web design form, the note and anything after it disappears from the survey. The note and additional fields will appear on the preview and they appear on the app if the survey is published. I have 2 notes in the form. Everything works fine on the first one note. It has a visible rule set "if the previous field is Yes/No". The second note I am making visible if a value of a field is greater than .85. The note functions right in the preview and the published survey and shows up on the schema, but it does not show on the design and it prohibits any additional fields from showing up on the design, although I know there are 4 more additional fields. What is causing this and how can I prevent? Is there a way to get these fields to show again? Is this a bug?
