I am in EB Developer 1.14 and noticed that my main basemap is appearing twice in the basemap gallery. The top instance is pulling from the AGO map and appears to have that map's default thumbnail. The second instance is what I added via Basemap Gallery > Configure Custom Basemaps > Import and that is pointing to an item in our organization's basemap group.
Both instances are hitting the same cached map service on ArcGIS Server. Is there a way to remove the top item or do I need to give my web map the same thumbnail as what you see in the second instance, which I don't want to do, or is there another way of removing the first item? FYI, I do not see the top item listed separately in this app's config file.
