I'm trying to create an auto incrementing UniqueID in Survey123 with Connect. I was surprised to learn that attribute rules are not honored by hosted feature layers that are not Enterprise. To get around this, I found a JS code. It will populate the UniqueID field with a '1' but it won't actually increment the number. It is an integer and I used it as a calculate question in Survey123 connect. Any ideas on if this is the correct logic?
function getUniqueID() {
var url = "https://services1.arcgis.com/dKlvxNSUvl36IGMp/arcgis/rest/services/Seatbelt_Survey_Sites_Pilot_2024/FeatureServer/4/query";
var params = {
where: "1=1",
outFields:"UniqueID",
orderByFields: "UniqueID DESC",
returnGeometry: false,
f: "json"
var queryString = Object.keys(params).map(key => key + '=' +
encodeURIComponent(params[key])).join('&');
var xhr = new XMLHttpRequest();
xhr.open("GET", url + "?" + queryString, false);
xhr.send();
if (xhr.status === 200) {
var response = JSON.parse(xhr.responseText);
if (response.features && response.features.length > 0) {
var maxID = response.features[0].attributes.UniqueID;
return maxID + 1;
} else {
return 1; //start at 1 if no records exist
} else {
return null;
