Seeking ideas/direction on how to implement the following:
We have a survey with nested repeats.
We use the INBOX to load the survey and the user can make edits to the related 1st repeat.
If any edits are done, we would like to automatically create one 2nd repeat record to guide the user to indicate / record what change was implemented (read edit log). Don't need to automatically define what exactly was changed. Instead just want to create the 2nd repeat record to allow the user to update what they have changed manually.
Currently this is all working except the user must manually create an edit log record (2nd repeat). I would like to force this 2nd repeat record to at least be created automatically, knowing that the user can still delete it if they must.
Your input is most appreciated.
Cheers, BKS
