I have an existing survey123 form that I'm looking to improve for the next collection. Here is the scenario:
I have 600 pre-determined survey points in 5 different regions of the state. Each region sends a crew to collect the survey for their region. In the survey form, each crew selects from a drop-down menu their region, the unique survey ID and answer all the questions for that point. They repeat that process for each survey point in their region.
This is what I want to add to my survey:
I'd like to plot all the survey points on a map. The surveyors will select their region from a filter and that will update the map to show only the survey points for their region. Next, they will drive and find the first survey point on the map, click that point, that will open the survey question and they will fill-out the survey for that point. Once they submit the survey, they will find the next point on the map and drive to the next survey point.
Currently, the surveyor drive around and look for the survey points on a google map. Once they arrive to the location, they fill out the survey and submit it.
The survey points are pre-determined and are on on a hosted feature layer (edit enabled).
I'm looking for documentation or maybe a video tutorial that will show me how to do all that. I know that this might be possible in ArcGIS Field Maps, but I like the Survey123 functionality and options.
Thank you.
