HI..
I'm using Survey 123 Connect desktop app (version 3.17.55) from Arcgis Enterprise Portal to build a survey form.
I have shared the survey form, feature layer with everyone (public) to access it without any credentials.
The survey form from the Mobile app(survey123) is possible to access without any credentials .
The issue is that it prompts to login when the survey link url is accessed through webbrowser
link of the url is in the below format
https://survey123.arcgis.com/share/<surveyitem id>?portalUrl=https://<portalname>/<webadaptor>
After clicking cancel, the login window disappears and i'm able to feed the input parameters in the form.
How to avoid the display of login window, even after sharing the access to everyone? It looks so messy and confused where i'm going wrong
Request to provide a workaround for this issue.
Thanks in advance.
