Hi there,
I would like to view either csv. outputs or excel workbook outputs of the survey responses from the SQLite file. I understand that I can resubmit surveys by copying the SQLite file into the database folder of the Survey123 Field App. However, I need to be able to review the survey submissions at the end of the day in table format without internet (similar format as if you were to export from the Survey123 website). I think the code provided by @JamesTedrick found here: https://github.com/tedrick/ReadS123DB will provide exactly what I need, however I am not sure how to make it run properly as I have no experience using Python.
When double click the readDb file, it opens for a second and then creates the SQLite file seen below. However there is no output file(s) of the data.
I found and used the response for issue: Error OUT_DIR does not exist" however this did not change anything.
Any help would be greatly appreciated!
Thank you,
Danni
