Hi! I have 5 facility inspection surveys that use a feature layer in AGOL. Each survey uses an Inbox expression in each survey to filter out points based on 2 attributes in the data (inspection area and inspection status). Is it possible to take user input for the inspection area they want to survey and populate the survey with only points for that area? End goal is to get to only managing a single survey, not 5. Thanks!
