Hi all,
I have made a Survey123 form from an existing feature layer in Survey123 Connect. I have matched all of the field types to the types they should be interpreted, and I have organized the question structures as they all should be. The survey published without issue.
Now I have ~2000 records that were published on the same day, I therefor cannot select and filter by submission date, but I do have a field called "Date" in my data.
When I open the Analyze tab, everything works fine without issue, graphs show up, can hide fields as needed, I can even subset by string values if I want. However, if I try to subset by my Date field with the filter "Date is between xyz/xyz/xyz and YY/YY/YYYY", the apply button, when pressed, will continually load endlessly without actually applying the filter.
I have tried to do this with every type of filter for the Date field - "is", "is not", "is between", "starts with", etc. They all fail to load.
Please help!
