Experience Builder allows you to add REST URLs as a data source, which is nice when you don't need or want a separate map just to make your data available to ExB. However, when you use a service as your data source, the table widget does not honor the integer formatting. I would like to have the ability to remove commas and decimal points from integer fields directly in the Table widget, rather than having to create a web map, configure the pop-up, and then use the web map as the data source. For my use case, I have an int field that contains years only. The year 2,022 looks odd!
