I'm using the format-date function to extract the various elements of date and time as follows but I cannot get the last element (0 padded seconds) to be anything other than 00 (i.e. '%S' below).
string(format-date(${dc_date},'%y'))
+ string(format-date(${dc_date},'%m'))
+ string(format-date(${dc_date},'%d'))
+ string(format-date(${dc_date},'%H'))
+ string(format-date(${dc_date},'%M'))
+ string(format-date(${dc_date},'%S'))
dc_date is defined as a datetime field with a default value of now() and bind::esri:fieldType to esriFieldTypeDate.
s_id is defined as a text field with the calculation set to the format-date function above and bind::esri:fieldType to esriFieldTypeString
I've tried changing the fieldTypes but this didn't have any impact.
Survey form spreadsheet with these two records is attached.
Anyone else with this issue / solution?
The result of the format-date calculation is as follows with the 00 at the end for seconds every time: 220707131700
