I have a map within my report template and I would like the scale to change depending on the particular site visited for each survey. This is because the map in my report uses an existing web map which includes site boundaries but the geometry of my survey is simply based on the centre of these boundaries. As the boundaries vary in size I want to make sure that all of the boundary can be seen in the map and ensure the scale is reasonable particularly for smaller sites.
I did try adding a map scale field into my survey and then to use this in the report template syntax as below but I get an error telling me my tags are unclosed.
${SiteLocation|mapSettings:"dc76a6ede3654335a996670a95664c20":${MapScale}|size:710:750|drawingInfo:"currentLayer"}
Has anyone found anyway to make the scale dynamic for different surveys? Any help would be much appreciated.
Anthony
