I designed a form for botany surveys, and it includes a repeat for plant species. I've been using it without any major problems until last week.
For the surveys my crew performed last week, the number plant species visible in via the inbox is less than the total number entries submitted. All the data was successfully submitted to the cloud, which I know because I exported all of the data to an Excel spreadsheet, and it contains the correct number of species.
Here are the number of entries visible in each survey:
- Survey 1: 117 out of 124 species
- Survey 2: 43 out of197 species
- Survey 3: 0 out of 98 species
- Test 1: 0 out of 5 species
- Test 2: 0 out of 5 species
I have two other repeats in the form, and I have not experienced this issue with them.
Every repeat field in the XLS form has "query allowUpdates=true" in the bind::esri:parameters column.
This just started happening last week. So what changed? Well, I republished the survey last Monday with some minor changes: I added some more plant species in the choices sheet, and I made one of the fields in the plant species repeat a required field.
Last week was also the first time we had two surveys performed simultaneously using a tablet we hadn't used before.
Any ideas on what could be causing this or how I might fix it?
