Hello! I am having issues exporting my Survey123 data to Excel. I am using Connect to build my survey for reference. Upon export, my Excel file has multiple tabs instead of just one. My survey does include repeats. For further reference, repeats are included in the survey for when a survey taker sees the same type of wildlife sign again and needs to add an extra data point. Is there a way to condense the exported Excel sheet into a single tab? Or a different way to structure the survey in Connect so I don't have this issue? Thanks in advance!!
(Side not: I am also having issues with the data output in Survey123 showing text and note fields as a field type... how do I include a text field in a survey without it showing up in the field type of the data? I have tried putting 'null' in the 'bind::esri:fieldtype' but the field still shows up upon viewing the output data..)
