Hi there, I know this is a known issue with Survey123 but I'm still trying to resolve a workaround.
I am building my form using the web developer app and can edit, save, publish. However, in order to create repeats on an embedded set of questions, I need to switchover to the Survey123 Connect desktop app and modify the xls fields.
When I save those changes, they do not appear to update if I reopen the form on the web developer or download the form to a device.
My problem in the past has been that in order for those repeat fields to show as an update, I need to publish the form from the desktop app. But when you publish from the desktop app, you can no longer make edits to the form from the web developer. The form is locked, and you cannot create a copy either.
I am looking for a solution that allows the repeat questions to be updated on the web developer and when downloading to a device, in such a way that I am not required to publish the form from the desktop app and thus, lock the form from future edits. I've managed it in the past, but I can't for the life of me figure out how I did it.
