Enjoying the notebooks available within ArcPro 2.5, but it would be nice to have the nbconvert options to export to other format (html, reveal slides).
Export to items were added to the Notebooks UI with Pro 2.8:
Dan,
We will be addressing the need to have these standard Jupyter Notebook elements back in the notebook interface -- but as you mentioned, the underlying code is already present (nbconvert), as is Jupyterlab for folks who want to use that in a standalone interface.
Cheers, Shaun
Hi Dan - no specifics yet - just moved to in product plan but I've shared your questions with the dev team...
Cheers
Seems to be change to "in production plan" Any details Kory Kramer ?
Will it be a fully-fledged *notebook/*lab?
Will the dependencies reside in the site-packages path so that they can be shared by other packages or are they housed elsewhere ?
I think they are trying to keep the interface small if you want to use it inside of Pro...Using it outside it is full-fledged and you can use jupyter lab too if you want more options
I was looking for the typical UI elements that one would expect with a stand-alone notebook. But I suppose this is a work-around.
already offered
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
