This video is a quick introduction to COGOing a traverse in ArcGIS Pro.
For more help and examples read the help documentation.
See previous video on GeoNet to learn how to Enable COGO on a line feature class (it's really easy).
Hi Amir,
Thank you for the video demos.
Can you please provide a status update here for the related ideas listed below?
Your reply will help determine ArcPro adoption timeline in enterprise deployment with this recent poll.
ArcGIS Pro Adjust Traverse
Add full COGO functionality to ArcGIS Pro
ArcGIS Pro support for importing and exporting traverse files
-Bill
Hi Bill,
There are many ideas expressed on those threads, which I have tried to some up here:
Amir
FYI:Kory Kramer, Christine Leslie
Tangent bearing
tb or TB
Bearing
41-56-06-4tb (using quadrant bearing)
Radial bearing
rb or RB
41-56-06rb (using quadrant bearing)
Chord bearing
cb or CB
41-56-06cb (using quadrant bearing)
Chord length
c or C
Arc Length, Delta Angle
25.01c
Delta (central angle)
d or D
Arc Length, Chord Length
90-59-59d
Arc length
A or a
Chord Length, Delta Angle
25.01a
@AmirBar-Maor
We appreciate the video.
Can you help with entry of this traverse using ArcGIS Pro 2.8.2?
Segment: Curve
Length: 355.26' Radius: 7959.44'Delta: 002°33'26" Tangent: 177.66'Chord: 355.23' Course: S87° 04' 17"WCourse In: S01° 39' 00"E Course Out: N04° 12' 26"W
"...THENCE leaving said south right of way line South 00°52' 45" East, a distance of 747.35 feet, to the northerly right of way line of roadway and the beginning of a non-tangent curve to the left from which point the radius point bears South 1°39'00" East; THENCE 355.26 feet along said northerly right of way line the arc of said curve to the left, having a radius of 7959.44 feet, through a central angle of 2°33'26" and a chord bearing of South 87°04'17" West; ..."
Thanks for any help!
To enter this into the traverse it would look like screenshot below, you will have to use the RB, radial bearing override for the non tangent curve described here:
"a non-tangent curve to the left from which point the radius point bears South 1°39'00" East"
To check this you can use the Direction Distance measure tool to verify the chord direction and distance are correct:
"Chord: 355.23' Course: S87° 04' 17"W"
Oh. OK. Thank you! Will try this!
