I want to use existing external data in a survey using the pulldata() function. The existing data in the csv will need to be updated weekly. To have this data available to the users of the survey I guess the survey with the updated csv will need to be republished each time. Is there a way to automate the publishing of a survey rather than having to manually open Survey123 Connect and go through the publishing process each time?
Regards,
Finnian
