I don't understand how fields w/ Date data types could possibly generate a time.. " ,7:00" time at the end. See the img below. We're using the Portal dashboard. How do I prevent a time from showing?
Hi Jordan,
Try configuring the Date attribute in the web map's pop-up property to remove the time.
1. Open the web map in the Map Viewer (either ArcGIS Online or Portal for ArcGIS).
2. Click configure pop-up for the desired layer in the web map.
3. In the Configure pop-up dialog, click Configure Attributes.
4. In the Configure Attributes window, select the date field and uncheck the Show time checkbox.
5. Click OK to save your changes.
This should remove the time stamp showing in the element, when you re-open the web map in Ops Dashboard.
Hope this helps,
Hi Derek
In my dashboard I use related tables for the graphs and configured all the dates as 13/12/1997 (European, without time) in the web map. Yet the dashboard shows the dates as 12/31/1997, 12:00 AM. The charts either use the date field as value for grouping, or as category field when displaying features, for both cases "parse dates" is switched on.
Can you confirm this? Is this "as designed"? IMO, the dates should be shown as configured in the web map.
Annina
datetime
format date
date configuring
operations dashboard web version
Hi Annina,
Apologies for the late reply, I was working at the EPC/Dev Summit conferences this week.
I'm not 100% clear on the details of your workflow, can you please send me an email, detailed repro steps and perhaps some data so we can take a look? Email: dlaw@esri.com
Derek
Hi Derek,
Did you find a solution to be able to display dates without the time in Operations Dashboard?
I have configured the pop-up in the web map to not show time however it does not apply this to the list in Op Dashboard.
Richard
Great! Solved!
I am running into the same problem. I have a table with dates only. When I display it in a dashboard it adds a time stamp. The problem is this also shifts the date by a day. It appears to be a shift caused when appending data into portal. For some unknown reason the table on portal wants to convert time. (this is an error)
So if I do the work around to add it to a map and then remove time. Its the day before.
Ryan, the issue with the time stamp might be that most map and feature services use Coordinated Universal Time (UTC), which for me is 8 hrs beyond my local time zone. This pushes some records into "tomorrow". To resolve this, choose a specific time zone in the Configuration Options when publishing from ArcGIS Pro:
Hi GKeily,
I have tried playing around with that configuration feature. The problem is we want to append data after the layer in published. It seems using the append in model builder in Pro, when appending the time zones applied to the layer is ignored.
The only work around I have found is to have two date fields.
One for local time PST and one for UTC. If a user is consuming the data in pro, use the PST time, If they are using the data in enterprise use the UTC field.
We are a city so we never need to show things in another time zone. And if a user was accessing city data outside of the area, it would be safe to assume the data is shown in the local time.
Of course changing the way time/date is applied to the entire enterprise system as this point would be quite the task. Would be great if there was just a way to turn off the automate time conversion and just use the date exactly as entered. i.e. 12/13/2021 12:00am would always show as that time, no matter the environment it's being loaded in
