I get the following message when I try to perform Interpolate Points:
InterpolatePoints failed."
I tried a lot of different variations and keep getting the same message. What could it be?
I use ArcGIS Enterprise Standard.
In a similar post someone answered that Interpolate Points is available only with GeoStatistical Analyst, but this option is available under the standard tools / standard analysis.
Also, If I try with < 10 points, is shows the message:
Not enough data to compute method. At least 10 points are required. InterpolatePoints failed." which makes me think it is not a license or permission problem.
It is also not a role/privilege issue (I have Publisher role).
Thanks in advance
https://community.esri.com/thread/196221-what-license-is-required-to-perform-spatial-analyses-by-interpolate-points-tool-in-arcgis-105-with-portal
https://community.esri.com/thread/119201
https://community.esri.com/thread/206112-i-have-an-arcgis-school-bundle-account-and-im-the-admin-i-am-trying-to-use-the-analysis-analyze-patterns-interpolate-points-ive-uploaded-a-csv-file-that-has-10-points-for-elevation-the-range-is-7238-7254-i-watched-this-video-to-run-the-an
All related threads
Hi Dan! Thanks for the message
I've found these threads before, two of them do not relate to the Error message I'm getting and the other, I believe, has an insufficient answer.
It is definitely not a problem of having less than 10 points, as this Error message ("Not enough data to compute method. At least 10 points are required...") is shown only when I use, in fact, less than 10 points.
Under this thread
the provided answer seems inaccurate as I mentioned in my thread. I list the reasons:1) There is Interpolate Points under Standard Analysis (it is listed in http://enterprise.arcgis.com and otherwise the option would not even be available (visible) to me).2) If I try to use Interpolate Points with < 10 points it asks for more points (why would it do it if the tool is not available for my version?).
The reason for this Error is still unclear to me.
Geostatistical analyst perhaps?
https://enterprise.arcgis.com/en/portal/latest/use/interpolate-points.htm
Then the standard caveats of privileges, permissions and signin
Interpolate Points uses Empirical Bayesian Kriging to perform the interpolation, which is available in the Interpolation toolset of the Geostatistical Analyst extension toolbox.
Interpolate Points is also available in ArcGIS Pro. To run the tool from ArcGIS Pro, your project's active portal must be running Portal for ArcGIS 10.5 or later. You must also sign in to the portal using an account that has privileges to perform standard feature analysis in the portal.
Hi Dan,
From what I understand in this link the Geostatistical Analyst extension applies to ArcGIS Desktop.
The error message in the log refers to:
Error executing tool. .... {"messageCode": "AO 100104", "message": "InterpolatePoints failed."} Failed to execute (InterpolatePoints).
Does it say anything to you?
I did not find this same error code in other threads.
Thanks again
Did you ever find a resolution? I encounter the same problem in Portal.For the record, I tested Bayesian Kriging and the process worked flawless, so I know the dataset is fine.
Hi Paul
Unfortunately no.
I've been using interpolation tools on Desktop and then exporting it to Enterprise. Likewise, I'm also confident that the input data is not the problem.I filled a request with ESRI technical support some weeks ago but got no answer.
Hi William,
Is there any way you can provide your data? I know data is often confidential, but the only way this will get resolved is if we can run it in a debugger to get better error information. If possible, attaching a zip file to this thread will be easiest. If that is not acceptable, please let me know, and we can figure out a confidential way to figure this out.
Hi Eric,
thank you for your reply. As you mention, the data I'm working with is confidential. Nevertheless, I attached a file (Analysis.zip) which I used to verify if number formats and distribution could be affecting the interpolation (that's why you will find 10 fields with random numbers). I got the same problem I described in this thread with this data.
For the record, the real data format is double and the points are not so far from each other.
I do not think this issue is related to your data; I was able to run Interpolate Points with your attached data without any errors.
Instead, the issue is almost certainly related to licensing. Interpolate Points requires an Advanced license for ArcGIS Enterprise in order to use the Geostatistical Analyst extension (which only comes with an Advanced license). If you have a Standard license, Interpolate Points will fail on execution, and this is probably what is happening for you. This will also happen for the Calculate Density tool because it requires the Spatial Analyst extension. Can you confirm which version of ArcGIS Enterprise you are using and your license level?
Starting in ArcGIS 10.6, Interpolate Points and Calculate Density will no longer appear in the tool list if you have a Standard license.
We apologize for the poor communication of this problem, but I hope this clears up why the tool is failing.
Eric:
Is there good documentation out there on all the changes to the ArcGIS Enterprise licensing model in ArcGIS 10.6?
Are there any updates to this licensing model with the upcoming minor release of 10.6.1?
Dear Eric,
That leaves it very clear, as we are using Enterprise Standard, version 10.5.1 (updating to 10.6 soon).
Thank you again for your answers and effort to clarify this subject.
