We’re trying to publish scenes and we have not been able to get past this “root node” error. Here is what I’ve tried.
Workaround
How do I run Internet Explorer as a different user in Windows
To run an app as a different user in Windows 10, do the following.
Open File Explorer and go to the folder which contains the required app.
Press and hold the Shift key and right-click on the file.
In the context menu, select Run as different user.
Enter the new credentials and click OK to run the app.
1. Open Internet Explorer as the “arcgis” local user
Press and hold shift key and right-click IE shortcut\
2. Internet Explorer > Internet Options > Security > Sites
Disabled the option to Require server verification (https:) for all sites in this zone Added the http://mysite.domain.com URL for ArcGIS Server ( HTTP )
Added the https://mysite.domain.com URL for ArcGIS Server ( HTTPS )
Added the http://177.37.7.137 URL for ArcGIS Server ( HTTP )
ec2 instance Private IP – see the output of the command describedatastore.bat tile cache machines property, it uses the private IP) <== THIS SOLVED THE PROBLEM!!!!
Added the https://177.37.7.137 URL for ArcGIS Server ( HTTPS )
3. Internet Explorer > Internet Options > Advanced tab
Use TLS 1.2 was already enabled
Use SSL 3.0 was enabled
per suggestion on this forum article
https://community.esri.com/thread/194033-root-node-is-not-available-for-layer-open-published-scene
4. Data Store Property
Connected to the Tools folder in “C:\Program Files\ArcGIS\DataStore\tools” and ran describedatastore Ran changedbproperties --store tileCache --enablessl admin,data >> Operation completed successfullychangedbproperties:https://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm#ESRI_SECTION1_5F78275E9F6A42D199FC7098DFF049AB
enablessl: This parameter controls use of the Transport Layer Security (TLS) protocol when populating the tile cache data store.
Supported options for the enablessl parameter are as follows:
5. Reboot the ec2 instance
AWS EC2 Multi Machine Deployment - Workaround Details
Press and hold shift key and right-click IE shortcut. Run as Different User…
This did not work. I was able to open IE but the IE Trusted Sites changes did not persisted.
Workaround:
granted "remote desktop user" role to the local “arcgis” user then logged in and verified IE settings.
re-applied the settings
logged off/in, opened IE and settings were fine now
revoked “remote desktop user” from local “arcgis” user
disabled the option to Require server verification (https:) for all sites in this zone
add these HTTP URLs
http://agi-dev-3.esri.com
< ec2 instances Private IPs >
http://172.31.17.247 ags-dev-portal-3
http://172.31.17.87 ags-dev-data-store-3
http://172.31.17.247 ags-dev-data-store-spatial-3
add these HTTPS URLs
https://agi-dev-3.esri.com
https://172.31.17.247 ags-dev-portal-3
https://172.31.17.87 ags-dev-data-store-3
https://172.31.17.247 ags-dev-data-store-spatial-3
ags-dev-data-store-3 – Data Store ( Relational & TileCache)
changedbproperties:
Question:
I am able to publish the scene service but I’m having issues with some textures being dropped. I don’t think it’s a problem related to this issue but I’m still troubleshooting. Any ideas by chance?
Answer:
Disregard, just needed to rebuild the cache. Everything appears to be working as normal now.
FYI for the future: If you are using 10.7.1 or above software then you don’t need to run steps 3 and 4. They are fixed in the software and will be of no use to set it up.With 10.8 all we know is to perform step 2 on some OS and in cloud solutions where the security level is higher and therefore we need to add the machines as trusted sites. This is not Esri software issue but the OS security level issue.
