I'm using JS API 4.6 and I'm trying to show in a table all graphics been displayed in the current extent directly querying the client/view.
You can find a live sample of the skeleton I'm using here or directly in here:
<SPAN class="doctype token"><!DOCTYPE html></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">charset</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>initial-scale<SPAN class="punctuation token">=</SPAN>1,maximum-scale<SPAN class="punctuation token">=</SPAN>1,user-scalable<SPAN class="punctuation token">=</SPAN>no<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Query graphics on webmap<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.6%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.6/esri/css/main.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="keyword token">var</SPAN> dojoConfig <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
has<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"esri-featurelayer-webgl"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.6%2F" target="_blank">https://js.arcgis.com/4.6/</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="selector token">html,
body,
#viewDiv</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 400px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/Legend"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/geometryEngine"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/core/watchUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
WebMap<SPAN class="punctuation token">,</SPAN>
MapView<SPAN class="punctuation token">,</SPAN>
LayerList<SPAN class="punctuation token">,</SPAN>
Legend<SPAN class="punctuation token">,</SPAN>
geometryEngine<SPAN class="punctuation token">,</SPAN>
watchUtils<SPAN class="punctuation token">,</SPAN>
Query
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
webmap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"19d21df5e87f4f5a9aa5b8d678b174d6"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> webmap<SPAN class="punctuation token">,</SPAN>
popup<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
dockEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
dockOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
buttonEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
breakpoint<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1000</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-left"</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> featureLayer <SPAN class="operator token">=</SPAN> webmap<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getItemAt</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
featureLayer<SPAN class="punctuation token">.</SPAN>labelingInfo <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
labelExpression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"[title]"</SPAN><SPAN class="punctuation token">,</SPAN>
labelExpressionInfo<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"expression"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"$feature[\"title\"]"</SPAN>
labelPlacement<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"always-horizontal"</SPAN><SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"text"</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.85</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
font<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN>
weight<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bold"</SPAN><SPAN class="punctuation token">,</SPAN>
family<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Arial Unicode MS"</SPAN>
haloColor<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
haloSize<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> legend <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Legend</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
layerInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
layer<SPAN class="punctuation token">:</SPAN> featureLayer<SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Actor type"</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>legend<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenTrue</SPAN><SPAN class="punctuation token">(</SPAN>view<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"stationary"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> info <SPAN class="operator token">=</SPAN> <SPAN class="template-string token"><SPAN class="string token">`the view extent changed: \n
xmin = </SPAN><SPAN class="interpolation token"><SPAN class="interpolation-punctuation punctuation token">${</SPAN>view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>xmin<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="interpolation-punctuation punctuation token">}</SPAN></SPAN><SPAN class="string token"> xmax = </SPAN><SPAN class="interpolation token"><SPAN class="interpolation-punctuation punctuation token">${</SPAN>view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>xmax<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="interpolation-punctuation punctuation token">}</SPAN></SPAN><SPAN class="string token"> \n
ymin = </SPAN><SPAN class="interpolation token"><SPAN class="interpolation-punctuation punctuation token">${</SPAN>view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>ymin<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="interpolation-punctuation punctuation token">}</SPAN></SPAN><SPAN class="string token"> ymax = </SPAN><SPAN class="interpolation token"><SPAN class="interpolation-punctuation punctuation token">${</SPAN>view<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>ymax<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="interpolation-punctuation punctuation token">}</SPAN></SPAN><SPAN class="string token">`</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>info<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewDiv<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Visible graphics:<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!-- TODO: Display visible graphics--></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I have been trying different things:
1) Using queryGraphics as I found at the GraphicsLayerView | API Reference | ArcGIS API for JavaScript 4.6
l <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN>allLayerViews<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getItemAt</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
l<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryGraphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"results="</SPAN><SPAN class="punctuation token">,</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But the "then" promise was not resolved, maybe because I didn't added in the right place.
2) So I tried using queryFeatures, similar al Robert Scheitlin, GISP suggested in Capture attribute values from a WebMap without click event directly on the console:
view<SPAN class="punctuation token">.</SPAN>allLayerViews<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getItemAt</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">always</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But this time I used "always" and I got an:
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"FeatureLayerView2D"</SPAN><SPAN class="punctuation token">,</SPAN>
message<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Not ready to execute query"</SPAN><SPAN class="punctuation token">,</SPAN>
details<SPAN class="punctuation token">:</SPAN> undefined
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>3) I didn't know what "Not ready to execute query" means so I keep trying this time using the view event layerview-create as Ken Buja mentioned atCannot access items array property of MapView.allLayerViews (ArcJS API 4.4) :
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"layerview-create"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">'1=1'</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>outSpatialReference <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"event.layer.title="</SPAN><SPAN class="punctuation token">,</SPAN>event<SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN>
event<SPAN class="punctuation token">.</SPAN>layerView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">always</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But I got the same error.
4) Next time I tried a different way, using layerView.featuresView.graphics as Thomas Solow mentioned at Design Question - Feature Layer Queries on Client-Side?
l<SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>title <SPAN class="comment token">// return "Startups"</SPAN>
l<SPAN class="punctuation token">.</SPAN>featuresView<SPAN class="punctuation token">.</SPAN>numFeatures <SPAN class="comment token">// return 374</SPAN>
l<SPAN class="punctuation token">.</SPAN>featuresView<SPAN class="punctuation token">.</SPAN>graphics <SPAN class="comment token">// return undefined</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
And I don't understand why graphics are undefined this time... ^_^. I also tried using queryFeatures on l.featuresView but the method didn't exist.
5) Desperately I also tried using the Accessor:
l<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"updating"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>newValue<SPAN class="punctuation token">,</SPAN> oldValue<SPAN class="punctuation token">,</SPAN> propertyName<SPAN class="punctuation token">,</SPAN> target<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
target<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"results"</SPAN><SPAN class="punctuation token">,</SPAN> results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"graphics="</SPAN><SPAN class="punctuation token">,</SPAN> target<SPAN class="punctuation token">.</SPAN>featuresView<SPAN class="punctuation token">.</SPAN>graphics"<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But nothing ;(
I have spent several hours reading, trying different things and searching in the answered questions, but I'm running out of ideas. Please, could you help me solve this problem? I guess it should be quite easy to do but I'm not able to make it work.
Thanks in advance.
