I have setup proxy server for my arcgis web app by following below links.https://community.esri.com/groups/technical-support/blog/2015/10/28/setting-up-a-proxy-with-web-appbuilder-for-arcgis-developer-edition https://community.esri.com/groups/technical-support/blog/2015/04/07/setting-up-a-proxy
It worked perfectly earlier, but then it started getting issue with one Url.
I am getting error "Unable to load http://localhost/DotNet/proxy.ashx?https://xyz.arcgis.com/sharing/rest/portals/self?f=json status: 0"
When i try to access link http://localhost/DotNet/proxy.ashx?https://xyz.arcgis.com/sharing/rest/portals/self?f=json from browser, it works and show some json data.
But, not through Application.My proxy setup is proper, I have checked it few times, Not sure what is the issue here.Let me know if you guys can help me here.Thank you.
Are you sure this is an ArcGIS Indoors issue? If not, I suggest moving it to the correct space, e.g. Web AppBuilder for ArcGIS in order to get an answer soon 🙂
