One of my users has a script that works in 2.7 and was working with 3.x but now breaks after the ArcGIS Pro 2.4.1 update. When copying an SDE table into memory using the arcpy.CopyRows_management all text field sizes are increasing from what there are to 5000. For example, text fields of size 1 and 100 become 5000. Our tables are a SQL 2012 / SDE 10.4.1 geodatabase. To see if I could replicate this issue I even created an empty table from scratch containing only two fields, the first is DataSource defined text length 100 and the other is Flag defined as text length 1.
Is anyone else seeing this? The user says it was working in version 3 before we pushed out Pro 2.4.1.
c:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>python.exe h:\treg\test_inmemory2.py
SDE table is : H:\Treg\(Prod) MyDatabase@Reader.sde\MyDatabase.DBO.WS_Test
OBJECTID is a type OID with a length of 4
DataSource is a type String with a length of 100
Flag is a type String with a length of 1
Copying table H:\Treg\(Prod) MyDatabase@Reader.sde\MyDatabase.DBO.WS_Test into memory...
temp table is : memory\tmpTable
DataSource is a type String with a length of 5000
Flag is a type String with a length of 5000
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">##Import modules</SPAN>
<SPAN class="keyword token">import</SPAN> os<SPAN class="punctuation token">,</SPAN> sys
<SPAN class="keyword token">import</SPAN> os<SPAN class="punctuation token">.</SPAN>path <SPAN class="keyword token">as</SPAN> path
<SPAN class="keyword token">import</SPAN> traceback
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
sdeTable <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"H:\Treg\(Prod) MyDatabase@Reader.sde\MyDatabase.DBO.WS_Test"</SPAN>
tmpTable <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"memory\tmpTable"</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'SDE table is : {}\n'</SPAN> <SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>sdeTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">##check field lengths in SDE text fields</SPAN>
fields <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>sdeTable<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> field <SPAN class="keyword token">in</SPAN> fields<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{0} is a type {1} with a length of {2}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">.</SPAN>type<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\nCopying table {} into memory...'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>sdeTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyRows_management<SPAN class="punctuation token">(</SPAN>sdeTable<SPAN class="punctuation token">,</SPAN> tmpTable<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\ntemp table is : {}\n'</SPAN> <SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>tmpTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">##check field length on in memory text fields</SPAN>
fields <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>tmpTable<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\n*** ERROR IN SCRIPT!'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\n***PYTHON ERROR INFO: \n'</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>traceback<SPAN class="punctuation token">.</SPAN>format_exc<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
