I was very excited to see that ArcGIS online now supports labeling. But when I use the same map in my operations dashboard, the labels are not showing up. Is labeling not supported in Dashboard yet, or am I just missing something?
Justin Nettleton and Dan Allen:
See this post:
https://community.esri.com/message/422764#422764
--Adam
It all depends on how you set things up and what kind of service that you are using.
If you are using your own install of ArcGIS for Server and a Map Service, you can see labels within Operations Dashboard for ArcGIS. If you are using a Feature Service, it does not support Labeling directly.
BUT recently, ArcGIS Online added labeling to the Web Map for either the Map Service or Feature Service - which can be seen in Operations Dashboard! Please see this document for instructions:
http://doc.arcgis.com/en/arcgis-online/create-maps/create-labels.htm
The labeling options are limited, but it is better than nothing!
I hope this helps!
EDIT: So, just now, I FULLY read your post.
I remember having this problem. When I was working with it, I found that you could not use the "/0" service (ID: 0). You have to use the service ending in "/FeatureServer".
Now I just tried to duplicate all of this and nothing is working!
Sorry - Back to the drawing board.
As the original post stated, I created a map in ArcGIS.com, turned on labels and they work great. But when I consume that same ArcGIS.com map in the operations dashboard, the labels do not show up. Does anyone know when this will be fixed?
Dan
as workaround
if you could enable <label features> from ArcMap before Publishing service, you'll get this view at Ops Dashboard Desktop edition
Labels in Dashboard. My workaround in the new online Dashboard was to add my map with labels as Embedded Content URL instead of adding as a Map. I don't know if Embedded Content has always been in the dropdown with graph, pie chart, map, serial chart, indicator, but it works. I can't tell the difference between adding as a Map vs adding as Embedded Content. I can also use the Batch Editing widget in the map within Dashboard.
