i would like to select distance in textbox and buffer with query in arcgis javascript iam using arcgis 10.1 post the code if anybody have
Thank u I have solved it
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Select with feature layer</title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
<style>
html, body, {
padding:0;
margin:0;
height:100%;
#messages{
position:absolute;
top:10px;
right:20px;
padding: 6px;
background-color: #ccc;
border-radius: 4px;
border: solid 1px #333;
z-index:99;
max-width: 150px;
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow:hidden;
#leftPane{
color:#000;
width:250px;
padding-bottom:15px;
#map{
.details{
font-size:14px;
font-weight:600;
padding-bottom:20px;
.ddl
{font-family:Verdana;
font-size:11px;
color:#666666;
font-weight:normal;
height:20px;
width:100px;
.inputtxtbox
height:18px;
width:60px;
</style>
<script> var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
<script>
dojo.require("esri.map");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.tasks.query");
dojo.require("esri.tasks.geometry");
dojo.require("esri.layers.FeatureLayer");
var map,tb;
function init() {
//identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
//If this null or not available the buffer operation will not work. Otherwise it will do a http post to the proxy.
esri.config.defaults.io.proxyUrl = "/proxy";
map = new esri.Map("mapDiv", {
// basemap: "streets",
center: [-95.249, 38.954],
zoom: 14
// dojo.connect(map, "onLoad", initToolbar);
landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("your url", { opacity: 5.55 });
map.addLayer(landBaseLayer);
//add the census block points in selection mode. Note that an info template has been defined so when
//selected features are clicked a popup window will appear displaying the content defined in the info template.
var featureLayer = new esri.layers.FeatureLayer("feature layer url@", {
//define a selection symbol that will be used to draw the selected census block points within the buffer polygon
// var symbol = new esri.symbol.SimpleMarkerSymbol(
// esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 12,
// new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_NULL,
// new dojo.Color([247, 34, 101, 0.9]), 1),
// new dojo.Color([207, 34, 171, 0.5])
var symbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255, 0, 0]));
featureLayer.setSelectionSymbol(symbol);
map.addLayer(featureLayer);
//Define the geometry service that will be used to perform the buffer.
var geometryService = new esri.tasks.GeometryService("geometry server url");
//when the map is clicked create a buffer around the click point of the specified distance.
map.on("click", function (evt) {
debugger;
var params = new esri.tasks.BufferParameters();
params.geometries = [evt.mapPoint];
params.distances = [dojo.byId("distance").value];
params.bufferSpatialReference = new esri.SpatialReference({ wkid: dojo.byId("bufferSpatialReference").value });
params.outSpatialReference = map.spatialReference;
params.unit = eval("esri.tasks.GeometryService." + dojo.byId("unit").value);
geometryService.buffer(params);
geometryService.on("buffer-complete", function (result) {
map.graphics.clear();
//draw the buffer geometry on the map as a map graphic
var symbol = new esri.symbol.SimpleFillSymbol(
esri.symbol.SimpleFillSymbol.STYLE_SOLID,
esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([255, 0, 0, 0.65]), 2
new dojo.Color([255, 0, 0, 0.35])
// var symbol = new esri.symbol.SimpleFillSymbol(
// esri.symbol.SimpleFillSymbol.STYLE_NULL,
// new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
// new dojo.Color([105, 105, 105]), 2), new dojo.Color([255, 255, 0, 0.25])
var bufferGeometry = result.geometries[0]
var graphic = new esri.Graphic(bufferGeometry, symbol);
map.graphics.add(graphic);
//Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic
//as the selection geometry.
var query = new esri.tasks.Query();
query.geometry = bufferGeometry;
featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (results) {
var totalPopulation = sumPopulation(results);
var r = "";
r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
dojo.byId('messages').innerHTML = r;
function sumPopulation(features) {
var popTotal = 0;
for (var x = 0; x < features.length; x++) {
popTotal = popTotal + features.attributes['OBJECTID'];
return popTotal;
alert(OBJECTID);
console.log(popTotal);
dojo.ready(init);
</script>
</head>
<body class="claro">
<div style="width:99.7%; border:solid 1px; border-color:#CFE5FA; height:99.7%">
<div data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="gutters:'true', design:'sidebar'"
style="width:100%;height>:100%;"
<div id="leftPane"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'left'">
<div style="background-color:#f1f1f1; border:solid 1px; width:100%; border-color:#CFE5FA; height:30px; font-family:Verdana; font-size:11px;">
<table cellpadding="0" cellspacing="0" border="0" width="100%">
<tr>
<td style="width:13%; text-align:left;">
<b>Buffer Parameters</b> </td>
<td style="width:48%; text-align:left;">
Spatial Reference WKID: <input type="text" id="bufferSpatialReference" value="32644" class="inputtxtbox" />
Distance: <input type="text" id="distance" class="inputtxtbox" />
<select id="unit" style="width:100px;" class="ddl">
<option value="UNIT_STATUTE_MILE">Miles</option>
<option value="UNIT_FOOT">Feet</option>
<option value="UNIT_KILOMETER">Kilometers</option>
<option value="UNIT_METER">Meters</option>
<option value="UNIT_NAUTICAL_MILE">Nautical Miles</option>
<option value="UNIT_US_NAUTICAL_MILE">US Nautical Miles</option>
<option value="UNIT_DEGREE">Degrees</option>
</select>
</td>
<td style="width:39%; text-align:left;">
<button data-dojo-type="dijit.form.Button" type="button" onclick="map.graphics.clear();">Clear Graphics</button>
</tr>
</table>
</div>
<%-- <div id="mapDiv" style="height:100%; width:100%"></div>
<div id="mapDiv"</div>
</body>
</html>
To get better answers, you should put your question in an appropriate space and add some tags. I have moved it to the ArcGIS API for JavaScript space for you and added tags.
There are some good samples to help you out. Take a look at this sample that uses a value from a text box to create a buffered feature. Then you can use that feature in a Query. There are a lot of examples on here with a quick search.
