Is there a way to paste from excel into multiple cells in an attribute table in ArcGIS Pro? There is a solution for ArcMap (Understanding how to edit values in a table—Help | ArcGIS for Desktop), but I can't find a solution for ArcGIS Pro.I need to be able to replace columns with data from excel. Thanks.
The first works on a cell by cell basis
the whole row thing isn't going to happen
Does anyone know when this might be addressed with newer versions of pro? The bug report for BUG-000111428 says it is in product plan, but the report that is excel specific says it is not in the product plan. Since these bug reports are from a year ago, I curious when and if they will be addressed. Not having this feature or a more seamless table edit workflow without double-clicking is slowing down simple data maintenance tasks.
You can check bug numbers directly on the Esri Support site
Esri Support Home
BUG-000111428: Unable to copy and paste consecutive cells from a ta..
BUG-000111595: There is no way to paste data copied from the Micros..
Has there been a solution?
We have an equivalency issue logged for this: [BUG-000111428: Unable to copy and paste consecutive cells from a table in another application into a field in an ArcGIS Pro table.]
I would recommend calling technical support to get attached to this issue which will increase the customer count.
Thank you!
Oh. I usually make sure I use Excel to table to handle the conversion
That's pasting data from the attribute table into excel, I need to paste from excel into the attribute table.
a related thread
https://community.esri.com/thread/203817-arc-pro-copy-past-attribute-table-into-excel
