I'm looking to embed a journal story map into the new story map design template. What font styles are used in the Summit Theme? I'd like to mimic those in the Journal Map
Thanks!
Sarah
The summit theme in the new ArcGIS StoryMaps uses Avenir Next for titles and Noto Serif for the body text.
If you want more info about fonts from other themes, take a look at the font choices in the Design panel's font pairings selector. It lists all of the fonts used in the available themes.
@KurtH The fonts and other aspects of the provided themes are documented here Set a theme—ArcGIS StoryMaps | Documentation.
Hi Owen, when you quote something in the new story map, which font is used? Like the one you see in the image
Hello -- Quotes use the same font as the titles/headings in your story. If you open the Design panel and look at the Font pairings, the first font shown is the title font.
Thank you so much Owen.
Hi Owen,
It appears the Design panel has changed. Is there another place to find the fonts associated with each theme now? If not, what fonts are associated with the "Slate" theme?
-Kurt
@OwenGeothanks so much!
Is there a way to use our own font other than what's available?
@jdcayetano -- When you build your own theme, you can pick from over 1000 fonts that are available through Google Fonts. For more detail, see Create a theme—ArcGIS StoryMaps | Documentation.
If your specific font isn't available via Google Fonts, there are often fonts that are very close. You can search the web for "Google Font alternatives" to your font.
There's not a way to add your own font right now, but we are looking into that. If you're interested in seeing that capability in ArcGIS StoryMaps, I'd recommend posting it to the ideas board.
@OwenGeo thanks for the link to the information about themes. There is one missing from this documentation - https://doc.arcgis.com/en/arcgis-storymaps/author-and-share/create-a-theme.htm, which is the ESRI Presentation theme.Can you provide the details for the ESRI Presentation theme? It is one of the new Feature Themes in the Featured Themes Gallery.
Hi @KathrynClifton ,
The Presentation featured theme uses Libre Franklin for titles and Wix Madefor Text for the body text. These are both font families imported from Google Fonts.
If you are using an ArcGIS Enterprise environment, you can enable Google Fonts for your organization using the steps in this Technical Article: Technical Support - Use Google Fonts in ArcGIS StoryMaps.
--Abby
@AbbyE_Esri Thank you for your prompt reply. I’m working only in an ArcGIS online environment.
are you able to provide additional details concerning the presentation theme as outline in the Standard Theme Reference in the documentation?
Sure, here are those parameters for Presentation:
Background color
#002433
Accent color
#72D0C8
Title and heading font family
Libre Franklin
Title and heading font color
#ECBF5B
Paragraph font family
Wix Madefor Text
Paragraph font color
#FFFFFF
Caption font color
#72B8D0
Button style
Quote style
Link style
Separator style
Separator alignment
Center
Basemap
Let me know if you have any additional questions about this featured theme.
