It´s possible to configure two webadaptor´s for a single portal? One in a machine to public access and other on another machine to access the administrator?
Thank´s
Hi Sorato,
Yes, you can configure two Web Adaptors for one Portal.
Keep in mind you will need to run the Web Adaptor installer twice to install two separate Web Adaptors; do not "double-configure" one Web Adaptor installation.
Hope this helps!
- Rachel
hmmm very good.
Can I do this for Arcgis for Server too?
Yes. The following documentation might be helpful:
Installing multiple ArcGIS Web Adaptors—ArcGIS Web Adaptor (IIS) Installation Guide (10.8) | Documentation for ArcGIS …
-- Rachel
Hello Sorato Marques,
There are circumstances where you would configure multiple portal Web Adaptors. Typically this would be for high-availability portal deployments. To configure multiple Web Adaptors with Portal for ArcGIS, a single endpoint must be used to access the portal. In additional it is necessary to configure a 'WebContextURL'.
Configure multiple ArcGIS Web Adaptors—ArcGIS Web Adaptor (IIS) Installation Guide (10.8) | Documentation for ArcGIS E…
Portal only supports a single DNS or one 'URL' to access the portal. For example it's not possible to have two portal Web Adaptors one in the DMZ and another internally using two different URL's.
https://community.esri.com/thread/215991-how-to-add-an-additional-web-adaptor-for-external-maps
Hope this helps,
Thomas.
