Hi guys,
due to this article:
ArcGIS Online | Service Credits
I have known that for an operation its equal to a credit,
Is it the same thing for Portal for ArcGIS or just for ArcGIS online ?
thanks for your help in advance
rscheitlin
Sara,
When using Portal (on premise) You are not connecting with AGOL or consuming credits.
https://community.esri.com/thread/89972#comment-370750
that means using ArcGIS server with Data Store and Portal, what's the case if I use Federated server ?
That is more of a question for others with federated server experience. dlaw-esristaff
Thanks for your help and time Mr. Robert
Sara_EL_MALKI
Portal will not consume service credits unless you assign a proxy named user in order to bring in services from ArcGIS Online. So if you are not using services from ArcGIS Online that consume service credits (i.e. Geocoding, GeoEnrichment, Routing, etc.) it will not use Service Credits.
Hi Sara,
Other have already replied to your original question. But for this one: when a Server site is federated with Portal - it just means that you've configured the Server site to use the security model that has been configured for Portal. A federated Server site does not directly affect/consume credits. Only a hosting server with Portal will use credits - as others have explained.
Hope this helps,
Hi Derek,
thanks for your response,
a hosting server with Portal means using Portal on premise,isn't it ? which means (as M. Robert said) it does NOT consume credits at all, but you've said the opposite ?
am I getting it wrong ?
Thanks in advance for your clarification
