AGSLineOfSight draws the line from an observer to a target in an AGSScene. Is there any way to get the coordinates of the point on the surface where the line "disappears" (ie transitions from visible to obstructed) - the method produces the lines, but I don't see any way to get the relevant coordinates. I don't see those properties in AGSGeoElementLineOfSight
Ie if I have an observer coordinate and a line (pitch and heading), can I get targetLocation, assuming the target is on a surface?
I see "Intersect 3D Line with Surface" in arcpy:
Intersect3DLineWithSurface_3d (in_line_features, in_surfaces, out_line_feature_class, {out_point_feature_class})
How can I do this (easily) in iOS?
I did see this
Can the geometry engine in 4.7 intersect a 3d line with a 3d polygon?
but it is pretty complicated and limited...
and Java sdk has
Line of Sight (3D Analyst)
with Output Obstruction Point Feature Class
: The output point feature class indicating the first obstruction point along the line of sight if the target is not visible.
-- looks like this last one is what I want...
