gp = arcgisscripting.create(93)
gp = arcgisscripting.create(9.3)
Hi Raymond, I'm personally unfamiliar with the finer details of the tool itself but can offer some suggestions. However your pictures aren't showing up - any chance you could upload them to an image host like TinyPic - I think right now the ones you've linked currently are password protected for me.
I'll mention this to Drew and see if we can get this script updated in the near future.
edit: There is an updated version available at http://www.arcgis.com/home/item.html?id=f4769668fc3f486a992955ce55caca18 that should work with 10.x out of the box.
Hi All (Phil Morefield you can help with this since you seem to know about this?),
I am writing in regards to the Huff Model that Drew Flater posted on ESRI's website since I seem to be running into a problem with it. The model is not generating outputs for all of my supply points, including my planned store location, whenever I run the model with a network I've created. I've followed ESRI's tutorial on creating multi-modal/pedestrian networks.
Hi All,I am having the same problem, and I try changing gp = arcgisscripting.create to (10.0) as I run on Arc 10, but I am still getting the same problem. Anyone have ideas how to resolve this issue?Thanks in advanceExecuting: HuffModel Auckland_firestations Name attract "C:\Mapping files\working\Decmeber files\Huff_tool\ToolData\SAMPLE" outputfeatureclass Auckland_FSA # # true NR2M_ND 2 NONE "Feature Set" true # #Start Time: Fri Dec 20 12:00:59 2013Running script HuffModel...Finished checking inputs against parameter requirements.PYTHON ERRORS:Traceback Info: File "C:\Mapping files\custom_toolbox\Huff_model\Script\HuffModel.py", line 371, in <module> attributes.reset()Error Info: <type 'exceptions.AttributeError'>: 'list' object has no attribute 'reset'GP ERRORS:Completed script HuffModel...Failed to execute (HuffModel).Failed at Fri Dec 20 12:01:02 2013 (Elapsed Time: 3.00 seconds)
