When I run my program in a VM, it fails to render a map, I see the 'powered by ESRI' logo in the bottom right,
just the map area is blank(white).
No errors in the log, shows:
Rendering engine: DirectX
Runs fine outside of a VM.
Could you try the solution at ArcGIS Runtime SDK for Java and Virtualization
OK, so I think I've figured out what caused the problem. If I use the 3d acceleration mechanism offered by VMs the rendering doesn't work, however if the acceleration is turned off it works flawlessly.
