I'm interested in writing my own desktop browser (for power users) for the OpenData catalog as an alternative to using the web interface at http://opendata.arcgis.com. Is there a way to directly access/search the catalog via an API?
Thank you,
JNU
Hi JNU,
There is an API - it is currently undocumented but you can access it here: https://opendatadev.arcgis.com/api/v2/
and explore it through an interface here: ArcGIS Open Data Developer API .
What kinds of things would you be changing or adding in your own interface?
Courtney
Hi, Courtney, and thanks so much for the speedy reply. I'm wanting to integrate it into a third party mapping application and be able to do an immediate search for datasets available for the current view, use saved searches, and be able to quickly select additional criteria to cull out returned datasets that are not of interest. It appears this API will allow me to fulfill my dreams.
Thanks again,
Josh Usovsky
Hi, Courtney. As a follow up to this, is there a list of available query ops and parameters available somewhere? I ran across a similar question(https://community.esri.com/message/599812 ) from a couple years ago, but didn't see anything else regarding this.
I'm specifically trying to find datasets within an area, now. I added a bbox param to the URL for retrieving datasets (e.g. http://opendata.arcgis.com/datasets?bbox=-98.3395151%2C29.873251399999997%2C-97.3395151%2C30.873251399999997), and although the first few results are good, eventually we start to see global datasets. Is there a way to specify that the datasets' bounding boxes must be within rather than just intersect my specified bbox parameter?
