Ik probeer een pop-up te configureren, maar er verschijnen geen velden in het venster 'Attributen configureren' waarmee ik ze aan of uit kan zetten. Wat zie ik over het hoofd?
Carolyn,
Look at this resource
Configure pop-ups—ArcGIS Online Help | ArcGIS
or here:
Related Tables in ArcGIS Online?
What browser are you using?
What type of layer did you add?
I created a map service from an .mxd. It's just a point FC in that map. Nothing terribly special about this. I'm suspicious that a table relationship is causing AGOL some trouble with reading the table information.
Dear Carolyn,
Kindly follow below mentioned links for clear understanding. Hope this will solve your issue.
Configure pop-ups | Learn ArcGIS
Thanks and Regards
Abhishek Rathi.
I am following those steps. When I get to this:
"Use the [+] button to select field values from your data. The field values contain field aliases followed by the field names. By default, the primary field is displayed."
No fields are present and there is nothing for me to select. If I click on a feature, I see all the fields included in the pop-up. I'm not able to configure this.
After further investigation, this seems to be happening only on feature classes that have that related table information. So... is it the case that pop-ups cannot be configured if there's related tables??
Thanks.
Can you add some screen shots of what you are experiencing?
Did you see my edit to my last response? This is only happening on features that have a related table. I can configure my other features just fine.
