Is it possible to migrate an application from Exp Builder Dev edition to ArcGIS Enterprise?
Yes -
https://community.esri.com/t5/arcgis-experience-builder-questions/deploy-exb-developer-edition-to-portal/td-p/1261371
thank you both. the workflow worked. i just added a comment there since it needs an additional step in 11.3
This is possible but there could be some steps needs to be done : 1) Ensure the version are the same. You may check here : https://developers.arcgis.com/experience-builder/guide/release-versions/
2) Might need to update the config.json before importing.
