Question for the Build Team: Why are layers loaded at run-time though the Add Data Widget or a custom widget so much better in the Select Widget than layers loaded from the webmap? And can we match the capabilities to webmap loaded layers?
Thanks for pointing this out. Some functionality or lack there of is just baffling. I am very disappointed in the query widget it that their is no runtime user functionality and you can only use prebuilt queries.
Hi JeffreyThompson2,
Thanks for bringing up this.
For the first, we are considering this and will keep you updated. For the second, I will reply you later.
Ke
When I brought this up, I was hoping you would make webmap loaded layers better, not make runtime layers worse.
I just found out that runtime layers no longer allow for both Attribute Selection and adding/removing/subsetting selections. I can confirm this in both 1.18 and 1.19.
