Hello - In prepping for the Enterprise 11.3 Portal upgrade this weekend, I just now noticed that the step for the Web Adaptor Uninstall - Re-Install has been moved from Step 3 in the upgrade documentation for 11.1:
https://enterprise.arcgis.com/en/portal/11.1/install/windows/upgrade-portal-for-arcgis.htm
3. Sign in to the machine hosting the ArcGIS Web Adaptor you're using with your portal, and uninstall ArcGIS Web Adaptor. For full instructions, see the uninstallation topic for IIS or Java (Windows). Be sure to note the name of the Web Adaptor before you uninstall it.
to Step 9 in the latest upgrade documentation for 11.3:
https://enterprise.arcgis.com/en/portal/latest/install/windows/upgrade-portal-for-arcgis.htm
9. Sign in to the machine hosting the ArcGIS Web Adaptor you're using with your portal, and uninstall ArcGIS Web Adaptor. For full instructions, see the uninstallation topic for IIS or Java (Windows). Be sure to note the name of the Web Adaptor before you uninstall it.
So in other words, we are now supposed to leave the 11.2 web adaptor version in place on my web server until AFTER we run the Portal upgrade and post-upgrade steps?
I've done this so many times since 10.6 and we have always removed the web adaptor BEFORE running the Portal Setup.exe. Can anyone comment?
@MarceloMarques
@A_Wyn_Jones
@JakeSkinner
@ScottTansley
Thanks -
David
Sarasota County GIS
