I just ran some geoprocessing on Pro 3.3 and noticed the "Suggestions" label in the status area. I don't need or care about getting suggestions for anything. That's what help systems are for. If I need something, make sure you have a good searching system so I can find what I need. So I looked for an option to remove it. I couldn't find one. In addition, I see that this Suggestions thing uses AI and requires the AI Models > Tool Suggestions to be installed which I didn't. So not only is it annoying that it's here, it's not even possible to use in my installation. If the required tools aren't installed, then it's shouldn't be here. Even if it was, this is still an annoying button/label/whatever it is and should be able to be enabled/disabled based on if the user wants it there.
