Hi all,
I've got a simple filter applied to unique field values that's working fine in my web map, but once I attempt to to the same via filter widget in Experience Builder only a few of the candidate values are appearing in the dropdown. See the two attached images for what I'm *ahem* experiencing. Currently running Enterprise 10.9.1. Is this some kind of bug?
Ben
@BenClark Yes, in the releases before the 2024 AGOL Mar release (11.3), the behavior is:
https://community.esri.com/t5/arcgis-experience-builder-questions/query-widget-unique-values/m-p/1353915/highlight/true#M9566
After that, the behavior is enhanced so that it will auto-populate the records based on search.
Huh, looks like increasing Page Size did the trick. I'm going to continue to mess around with this but going from the default 100 up to 1,000 now correlates with all of my unique values showing up in the filter widget.
