I've been searching the forum to see if anyone else has ran into this issue and haven't found much aside from this one post: https://community.esri.com/t5/arcgis-survey123-questions/issue-with-select-one-question-autocomplete-in/td-p/1364027.
I'm having a similar issue where I'm using the Search() appearance to retrieve my choice list from a hosted and linked CSV. When I open the dropdown menu in the form it immediately closes itself. I'm using this CSV for several lists in this form and so far none of the other fields have displayed this behavior.
I've linked my xlsx form in case anyone can take a look and see what's causing this.
Thanks!
Hi abureaux,
Thanks for the response!
I do all of my Survey123 development in Connect, and I am currently running v3.19.104, which I believe is the latest version. To be sure I uninstalled Connect and reinstalled using the MS Store version. Hopefully I'll get auto updates in the future as well.
Unfortunately, the problem persists.
My hunch is that is has to do with the fact I have a calculation running on that field to pulldata(@layer...). The field seems to behave as if it is overwriting my input immediately. The strange thing is I have other fields in the same repeat also using pulldata(@layer...) and those dropdowns are not behaving this way.
Anyway, I'm going to try splitting the manual input and pulldata into separate null fields and then coalesce them into a final field and see if that solves the issue.
Is this a web app? If so, which browser are you using and have you tried other browsers?
Also, if you are using Connect, is your Connect app up to date?
Beyond a potential browser issue or outdated Connect, I'm not sure what would cause this behaviour.
