Hello, I'm trying to use the Execute Data Load tool to migrate data into the utility network but every I run the tool I get the same error regardless of the reference workbook I use:
import pyarrow.lib as _lib
ImportError: DLL load failed while importing lib: The specified procedure could not be found.
As far as I can tell the the pyarrow package is installed and this problem happened on a completely different machine with a fresh ArcPro install.
Any help would be appreciated,
