The measure widget inside the experience builder's map widget doesn't allow any configuration. It would be great if we're able to set the default units of that measure widget to the any of the options available within the widget.
Hello @ScottKiley , there is a similar Idea already posted here. You might like to add your Kudos to that, to further raise it's profile.
https://community.esri.com/t5/arcgis-experience-builder-ideas/exb-make-the-built-in-widgets-to-the-map-widget/idi-p/1074432
The comments also point to a custom tool that apparently offers the functionality you are interested in.
I just logged in to suggest this! Definitely need this option.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
