I created a mobile map package with a custom Network Dataset to be used in Navigator It has worked in the past, now I am getting the attached error when I try to open in Navigator. Any help would be greatly appreciated. Thanks!
@AL_77 are you using any custom locators in your maps?
They are not showing as an option in Navigator, but are in Field Maps.
@AL_77 are your MMPKs not showing on Navigator or are you getting an error like the one above?
Any information or update? We are currently also having issues with MMPK showing up in Field Maps but not Navigator. Using Pro 3.2.
HI Cory,
Thank you for the context. I'll be on the lookout for the MMPK and I will follow up after I complete some testing.
Thank you,
Kerri
Hey Kerri,
All I did was change one vertex. I will send MMPK to that email address.
Cory
Can you give some more information about the change that you made to the network (just so I have a complete picture)? Where are you hosting the mmpk, is it in ArcGIS Online or Portal? Could you send a copy of the mmpk to the navigator email (ArcGISNavigator@esri.com) or make the mmpk public and send a link? I would like to take a closer look and see if anything pops out.
I made one small change to the network. I then re-built the network, checked geometry, and copied it. Now my maps aren't even showing up in Navigator at all.
Have you made any changes since the last time it was working, either with the Network Dataset, a new device, etc?
I have tried this and it didn't work. I event tried on ArcGIS 2.9 and 3.0 and it doesn't seem to work. I can pull the map up just find in Field Maps but not in Navigator.
Hi Cory,
There was an issue with ArcGIS Pro 3.1 when mmpks were published that would lead to problems with Navigator. There is a fix out now with ArcGIS Pro 3.2 Patch 2. https://community.esri.com/t5/arcgis-pro-documents/arcgis-pro-3-1-patch-2-is-now-available/ta-p/1293223 Try updating to this release, that should fix the problem.
Good afternoon,
I have the most up-to-date Navigator version in the App Store. For ArcGIS Pro, I am using 3.1. I did download this map in Field Maps app and it was able to open up there. Maybe it is is something to do with Navigator.
What version of Navigator are you currently using? And what version of ArcGIS Pro did you use to create the mobile map packages?
