I'd like to see support for CASE statements in a Definition Query, particularly where the data is in an Enterprise Geodatabase (SDE) with a database engine that does support this sort of query.
Can you give us a hypothetical example?
When I’ve used CASE in Oracle SQL, it’s usually in the SELECT clause in a full-blown query, not in the WHERE clause expression (a definition query essentially being a WHERE clause).
@Bud
Example as follows:
SomeField = CASE WHEN MONTH(GETDATE()) >= 8 THEN CONCAT(YEAR(GETDATE()), "-", YEAR(GETDATE())+1) ELSE CONCAT(YEAR(GETDATE())-1, "-", YEAR(GETDATE())) END
Unrelated, but the notes in this idea might interest you: Training course on SQL in ArcGIS Pro
We have a dataset with a field that defines the season of operations which is basically the years that a season spans concatenated plus a suffix, i.e. 2022-2023_<suffix>. A season starts in August, hence the month check in my example. That exact query works from SSMS (obviously this means we are using SQL Server) when I query the versioned view or business table, for example:
SELECT Field1, Field2, Field3
FROM SomeTable
WHERE <see previous example>
It does have a predicate because the case statement returns the season code which is then checked against SomeField.
Interesting. I think I get it now. I hadn't seen CASE used that way before.
I wonder why that doesn't currently work in ArcGIS Pro definition queries. If it's native SQL Server SQL, you'd think it would work. I don't see why ArcGIS Pro would treat it any differently than [WHERE] 1 = 1, or some other typical predicate.
I should add that the idea is to dynamically return the current season rather than having to explicitly set the current season as it changes.
I wonder if you could post a question on Stack Overflow or DBA Stack Exchange, with details like this:
A long shot:I wonder, is it actually a bug in ArcGIS Pro -- specifically a bug with how it handles definition queries on versioned data? Does it work on an unversioned table?
I ask because I had a similar issue:Using Oracle SDE.ST_GEOMETRY functions in a defection query or attribute table doesn't work -- due to a bug with versioning in ArcGIS Pro. But if I wrap it in a subquery, then it works fine. Or if the data is unversioned, it works fine too.
If you submit a case to support, and it turns out to be a bug, I suspect a bug would get fixed before an idea would get implemented,.
Thanks for that, I hadn't thought to test out wrapping it in a sub query. Will give that a go when I'm back in the office.
I haven't tested it on nonversioned tables either so will give that a go as well to confirm if it's a bug or not.
For what it's worth, your original syntax seems to work fine on Oracle tables in ArcGIS Pro, both on versioned and unversioned tables:
FIELD1 = (case WHEN 1=1 THEN FIELD1 end)
The brackets were just for legibility. They're not a subquery. It works without the brackets too:
FIELD1 = case WHEN 1=1 THEN FIELD1 end
Oracle 18c; 10.7.1 EGDB; ArcGIS Pro 2.6.8
Related post: Definition Query SQL shouldn't autocomplete WHEN to WHENEVER
For our notes, here's an example of your syntax working in SQL Server (the test has nothing to do with ArcGIS Pro):
https://dbfiddle.uk/shBxoaUj
How'd it turn out?
Sub query didn't work but I just realised I didn't test it against non-versioned data so will give that a try tomorrow.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
