We have a table on SDE that we want to switch from using Versioned editing as only one person is needed to edit that dataset and direct editing of the table is much quicker without versioned editing.
The issue is now that the table has been set to become editable, the "Undo/Redo" commands don't work, nor does the "Save Edits/Disregard Edits" work either (as they work fine editing say a shapefile or version editing tables in SDE). This means once an edit has been made, it's permenant, including mistakes which can be dangerous if things get deleted and can't be brought back.
Is there something we're missing that would allow is to still edit directly into an SDE table from ARCGIS Pro and still have those functions still work? Or is this just an issue with direct editing in SDE?
This is the first time we are trying this out and ran into this issue...
